421alkybanshee Posted February 3, 2013 Report Posted February 3, 2013 I hear yamahas like their oil meaning if you mix them richer, they run alot better, has anyone ever mixed it real rich? If your jetting isn't setup for a rich mixture, like let's say your carbs are setup to run at 32:1 and you mix your fuel with more oil which you would think is "richer" is incorrect. You are actually displacing fuel with oil which is actually making a leaner mixture. Just sayin! 1 Quote
JAGeSage Posted February 3, 2013 Author Report Posted February 3, 2013 Thank you for the lesson, i never thought of it that way. Quote
HolySheet Posted February 4, 2013 Report Posted February 4, 2013 Golden Spectro 42:1 93 octane Bel-Ray 75w 50/50 From Advanced Auto Quote
bansheefromhell Posted February 4, 2013 Report Posted February 4, 2013 I've been using Lucas semi synthetic 32:1 for years and honda trans oil and for coolant I use engine ice Quote
Uf21 Posted February 4, 2013 Report Posted February 4, 2013 How can you know what mixture ratio your carbs are set up for? Quote
spurdy Posted February 5, 2013 Report Posted February 5, 2013 How can you know what mixture ratio your carbs are set up for? Typically you know what premix you like to run and then you tune your carbs on that mixture. Unless you are making drastic changes, I don't think you will have an issue. SP 1 Quote
00'yamahabanshee Posted February 5, 2013 Report Posted February 5, 2013 I have 28 pwk carbs and I run klotz R-50 at 50:1 on 91 pump gas. starts up every time on two kicks and if the bowls are dry. Quote
