Z400Banshee Posted January 31, 2013 Report Posted January 31, 2013 I just bought a chrome clutch cover with a new bearing and seal installed. I also have a new chariot ultra high flow impeller that I tried to install but when I put the impeller shaft in the bearing, it just spun in the bearing. I loosened the bearing up and it spins a lot more freely than what it did but it still just spins in the bearing race. Looking for ideas to fix it Quote
dirtydownunder Posted January 31, 2013 Report Posted January 31, 2013 whats spinning ? impeller shaft inside the bearing. or bearing inside the cover ? Quote
sheerider11 Posted January 31, 2013 Report Posted January 31, 2013 From what I'm reading, that sounds about right. Quote
Z400Banshee Posted January 31, 2013 Author Report Posted January 31, 2013 The impeller shaft is spinning inside the bearing and the bearing is not turing at all. Quote
Starwriter Posted February 1, 2013 Report Posted February 1, 2013 Sounds like either crud in the bearing or somehow the inner race is mashed up against the seal. The bearing should spin freely. The gear is going to put some side load on it, but it sounds like the bearing is dragging too much. You're gonna have to do some investigative work on your own to determine why it's not spinning easily. Quote
