Translation? : Does this mean I have a long rod crank? Or possibly a stroker? I haven't given much info to guess at.
Compare old piston to new. Is the pin hole in same location? Do you have a cool head with stroker domes? Or did you have a head gasket about 2mm thick?
Did the old piston stick out similar height?
So wait let me get this right. If I am reading this right you bought one O.E. piston for your banshee and only are repalceing one???
Well, having experience with 2 strokes is gonna help. Although banshee's are 2 stroke and they are a quad, they are a stand alone bike like no other. Actually its like two engines working as one. I think a dual carb set up works better. Just look around here and read,read,read! They can be extremely frustrating and also very rewarding,
