banshee8zero2
Everything posted by banshee8zero2
  1. Is it a blaster style or a blaster piston?
  2. I know it has hot rods long stroke cranks I am wondering. If I can put the spacer plate in and run stock pistons
  3. I think I need a bottom but need advice
  4. http://http://www.bansheedepot.com/products.asp?cat=59 Yeah I'm pretty sure
  5. Does anyone know if I can use an alumnium shim spacer to run stock pistons in a 4 mill Stroker my local shop said he didn't know that I should buy a new top and bottom end from him
  6. Okay sorry man
  7. yes you're the douche beacouse you don't know what I've looked up.and this forum is a place to ask shit like this if you can find it any where else. You ignorant douche bag
  8. wow your a fucking douche
  9. I don't start two threads it does when I use the banshee hq app
  10. The cylinder gas been shaved down
  11. I have searched the internet for it and even order one that was supposed to be a 4 mill but sad not so I don't just wait for a response
  12. Thanks
  13. Where can I find a piston for a 4mill Stroker
  14. This is what I have the motor is not bored or ported I think it s a 4 mill
  15. How do I get to the last one to adjust
  16. Ya is 64mm and the # are On top it says STD and inside it says HR on the exaust side and S1 on the intake side
  17. It is not all stock where would the timing be adjusted
  18. How do I adjust timing
  19. Can I replace only the cranks to stock. From a 4 mill Stroker or do I have to do the whole bottom end
  20. How do I adjust the timing and where
  21. How do I adjust the timing and where
  22. Does that mean I have a 4 or 7 mm Stroker?
  23. Yes I replaced one I am getting compression from the other
