Hi,
I brought my banshee with the stock carbs bored to 28mm and I'm wondering what it is THEORICALY supposed to do to the jetting.
Say ProCircuit recommends a 260 for their pipe and a stock banshee should I go bigger/same/smaller with the bored carbs as my starting point ?
I was wondering the same with Vforce4 reeds and mild porting if I go down this road.
Thanks !
  • 1 month later...
What an increase in carb bore diameter does is actually decrease the pulse strength or draw on the carb. So, in theory you should up the jet a bit to compensate for the change in pulse as well as the additional air flow.
