06bluebanshee Posted January 4, 2013 Report Posted January 4, 2013 Hi guys I have a Banshee with: PC Pipes, VF3 Reeds, K&N clamp on Filter, No air box lid, stock pistons and cylinders. 800 feet above sea level. I'm wondering if a Noss Cool Head with 20cc domes would give me anymore power??? I know it will raise the compression and probably run cooler. But will it make anymore horsepower? Thanks for the help guys! Quote
Jereme6655 Posted January 4, 2013 Report Posted January 4, 2013 Yea it'll give it more power.....it will help kick that bike in the ass when you squeeze that throttle. HOWEVER......you gotta watch your compression levels as you can go over what pump fuels are able to run without detonation. I know im at 1000' and im running a FAST play/dune port, fmf fatties, vf2's and pods and 20cc domes give me 158 psi of compression.....which is getting CLOSE to being too much for comfort. also you may want to pull your motor down and have your crank trued and welded so that it doesn't separate. Adding compression is hell on a crank that is not welded.... Quote
