looking for...
Mattchev
You need to be a little more specific. There is supposed to be a tube welded to the frame that mounts the rear fender where it curves downward at the front part of the rear fender. If this part has been cut off and the frame powdercoated, I would fabricate an angle bracket off the unused stinger mount that's sort of in front of the silencer. Most people don't bother cutting that off. Bolt it up so you don't have to burn off the powdercoating. The other mount point goes off to the side from the grab bar and is part of the grab bar.
Yeah there's a screw hole in the fender where it curves downward that's pretty close to the frame and there's another screw hole on the fender that was where the heel guards were connected to it. I didn't know if there was an actual piece that is sold that connects the fender to the frame by the screw hole that's closer to the frame, not the heel guard screw hole. Hope that was a little better description.
