If it's the one in Sacramento area $300 maybe unless it's pulled apart and you can make sure there's no gouges in the cylinder and you would want to replace both pistons not just one so your looking around $300 since they are probablly 74 mm
Thats all? I figured aleast $1500... The billit cover on the side is worth $300 alone. It has been inspected the cylinders are fine, the piston has a pin hole size in it.
