472 supercub Posted November 14, 2012 Report Posted November 14, 2012 ii have a 472 supercub just put a new head on it chariot 24cc domes bike want stop running hot has high flow water pump everything looks to be fine but ? Quote
So Cal Suspension Posted November 14, 2012 Report Posted November 14, 2012 Everything's fine but your jetting. 9 times out of 10 a hot running banshee is attributed to lean jetting. I've ridden my bike in the glamis summer heat at 115+ for hours and hours, and it never overheated... Quote
472 supercub Posted November 14, 2012 Author Report Posted November 14, 2012 hvnt thought about that will get it checked thanks Quote
472 supercub Posted November 14, 2012 Author Report Posted November 14, 2012 if im running lean do i go up or down on jet size Quote
472 supercub Posted November 14, 2012 Author Report Posted November 14, 2012 im running 38mm pwk stock jetting Quote
vulvafan537240 Posted November 14, 2012 Report Posted November 14, 2012 go up. whats your jetting? Quote
472 supercub Posted November 14, 2012 Author Report Posted November 14, 2012 172 main 58 pilot what would be a good size to go to my bike is a 4mil long rod full drag porting 72m pistons cpi out side pipes straight cut gears vf 3 reeds 1-5 over ride trans Quote
locogato11283 Posted November 14, 2012 Report Posted November 14, 2012 Sounds to me like you're too rich. You should be closer to 162 main and 48 pilot. Yes, running way too rich can case overheating. Quote
472 supercub Posted November 15, 2012 Author Report Posted November 15, 2012 ok well ill buy a few differ ones and c how it goes Quote
472 supercub Posted November 15, 2012 Author Report Posted November 15, 2012 thanks did get me in the rite direction Quote
