tt_bansheerida Posted November 13, 2012 Report Share Posted November 13, 2012 well after some searching around i have not found another stator that looks close to it other than a rickey stator just wondering if anyone else hes seen or used this blue coloured stator Quote Link to comment Share on other sites More sharing options...
tt_bansheerida Posted November 13, 2012 Author Report Share Posted November 13, 2012 well after some searching around i have not found another stator that looks close to it other than a rickey stator just wondering if anyone else hes seen or used this blue coloured stator i took another stator out to compare this one has 2 yellow wires a green and red so im guessing the one yellow should be the white wire im not sure if it came like this or someone thought they knew what they where doing the one yellow wire was cut and not being used for anything this diagram says there should be 6 wiring coming from the stator i have 7 on this one http://www.dfn.com/agservices/banshwdc.jpg im just confused with this any help will be appreciated Quote Link to comment Share on other sites More sharing options...
notsed Posted November 13, 2012 Report Share Posted November 13, 2012 could be like said above most likely, but maybe converted to run dc also Quote Link to comment Share on other sites More sharing options...
Starwriter Posted November 13, 2012 Report Share Posted November 13, 2012 Get out your multimeter and start checking resistance. Yellow to yellow, yellow to ground, etc. Quote Link to comment Share on other sites More sharing options...
tt_bansheerida Posted November 13, 2012 Author Report Share Posted November 13, 2012 will do thanks ! ill have some feed back for you in a bit Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted November 14, 2012 Report Share Posted November 14, 2012 Looks like an Electro Sport Stator. I run one in my raptor and it has been fine for me. I dont know if they still use the blue coating or if they went to a clear. My raptor one has the clear sealent but pics on there web site do show some blue ones. The blue ones look like the sealant is a lot thicker and heavier, and was hopping my raptor stator would have had it but it didn't. http://www.electrosport.com/products/stators/ Quote Link to comment Share on other sites More sharing options...
Dicklez Posted November 14, 2012 Report Share Posted November 14, 2012 Throw it in the trash. OEM or nothing. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted November 14, 2012 Report Share Posted November 14, 2012 Electro sport AKA moose. 250w. It has 3 circuits one ignition and 2 lighting circuits (125w each) Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted November 14, 2012 Report Share Posted November 14, 2012 Electro sport AKA moose. 250w. It has 3 circuits one ignition and 2 lighting circuits (125w each) Ya, like u know anything about it..... Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 14, 2012 Report Share Posted November 14, 2012 not mentioned, but it also apears likely to be a banshee retrofit. the banshee flywheel has 12 alternating magnets, which is how it works. this one has to be operating with each circuit on every 3rd pole, set-up to work on the 12-pole flywheel. check if the yellows ohm to ground. doesn't look that high of power either, but i suppose it is possible. the 12-pole flywheel and 18pole stator is not uncommon, but the patched wiring looks like it might be intended for dc oem use. the blue is real potting, and i haven't seen real clear potting, just opaque cream would be the closest. clear is an enamel of sorts, which has higher cooling ability than the thick potting media. i haven't heard bad about electrosport/moose, but those ignition coils show they have seen some heat.... Quote Link to comment Share on other sites More sharing options...
