RadarRacing Posted October 21, 2012 Report Posted October 21, 2012 This seems pretty common with the HD / Streetbike clutches. Dont know which you have. I switched from ATF to Rotella oil and most of my creeping is gone finally with the normal clutch plates. Quote
sheerider11 Posted October 21, 2012 Author Report Posted October 21, 2012 This seems pretty common with the HD / Streetbike clutches. Dont know which you have. I switched from ATF to Rotella oil and most of my creeping is gone finally with the normal clutch plates. Hmmm. I run atf. I'd hate to pull this clutch just because it is so new. I will try the rotella tho Quote
sheerider11 Posted October 21, 2012 Author Report Posted October 21, 2012 But that's on the back burner after today steering stem is bent, and the flywheel rivots started to loosen. This bike is falling apart in front of me. Quote
nmdesertbansheeryder Posted October 22, 2012 Report Posted October 22, 2012 rough day out there,how did the a arm damage happen? Quote
sheerider11 Posted October 22, 2012 Author Report Posted October 22, 2012 rough day out there,how did the a arm damage happen? Hit a tree. And you can't really see but the rivots pushed the material back from rocking around. I have about 2 cm of play each way. Just glad they didn't shear off and really F things up. So there's another part for the wall of shame. Never riding in the woods again. I'm only sticking to sand. Quote
sheerider11 Posted October 24, 2012 Author Report Posted October 24, 2012 Any one have any ideas about the lurching? I'm still trying what ever I can. I'm gonna go with another new cable just because there really cheap. Quote
