Paulie B Posted October 17, 2012 Report Posted October 17, 2012 I know they are older and I can't really find any info on them. I'm wondering what kind of porting they come with as cast. Quote
#1JUANstunna Posted October 17, 2012 Report Posted October 17, 2012 PM BansheeHP I bet he knows. Quote
WINDYCITYJOHN400 Posted October 18, 2012 Report Posted October 18, 2012 Haven't dealt with the 10 mill cylinders, but the 4 mills have pretty high intake porting. (I think they were 198-132) We ended up running a 7 mill crank to get the timings back in line. (I think there is a bike in the for sale post listed as a 103HP bike that has the same combo of 4 mill cylinders and 7 mill crank.) NOTE: the cylinder material is a little weak at this point, so they have to heli-coil the head stud holes before they leave Vito's. We had 3 head studs pull out heli-coil and all just torquing the head down for the first time. With a TON of porting and adding worm holes we got the ones we were reworking up to 89.8HP on pump gas, but the torque was still a little low. So.......I'm still a CP cylinder fan as far as that goes. Quote
Paulie B Posted October 18, 2012 Author Report Posted October 18, 2012 Aw man not the info I was looking for but I appreciate you sharing. I had had the head off several times without helicoiling the studs so either they fixt that or I'm getting lucky. At this point these jugs seem to be the exact opposite of what I want. Quote
coryv4 Posted October 18, 2012 Report Posted October 18, 2012 Aw man not the info I was looking for but I appreciate you sharing. I had had the head off several times without helicoiling the studs so either they fixt that or I'm getting lucky. At this point these jugs seem to be the exact opposite of what I want. what exactly do you want paulie? if you want alot of torque and midrange get a 4mil or 10 mil serval with a clean up port. Quote
Paulie B Posted October 19, 2012 Author Report Posted October 19, 2012 I want the low-end torque and a nice curve. Do they have super servals out yet? Quote
BANSHEE HP Posted October 20, 2012 Report Posted October 20, 2012 vitos 10mm cylinder are full drag ported out of the box...pro circuits are not the recommnended pipe Quote
Paulie B Posted October 20, 2012 Author Report Posted October 20, 2012 I wouldn't be surprised if they weren't making 70-80hp right now. Quote
BANSHEE HP Posted October 20, 2012 Report Posted October 20, 2012 I've had two pairs of vito 10mm cylinders, one a little more ported then the othe. They made 94 and 98hp on pump gas, 40mm carbs and shearer bb inframe pipes. Also between those two sets and a stock stroke set I had, no stripped studs or helicoils Quote
WINDYCITYJOHN400 Posted October 22, 2012 Report Posted October 22, 2012 Well the cylinders are coming with heli-coils holding the head studs in as shipped. You don't have to do it....they did already. We had 3 heli-coils pull out and had to use timeserts to get the studs to hold. Fully ported 4 mill cylinders with 7mill crank, 34PJ's and small bore shearers 89.8 HP on pump gas. Quote
pabansheematt Posted October 22, 2012 Report Posted October 22, 2012 Vito's cylinders are made in China JUNK. I'd avoid them if you like riding. Quote
pabansheematt Posted October 22, 2012 Report Posted October 22, 2012 I see some shit head deleted my sig pic. What a fag. Quote
Paulie B Posted October 22, 2012 Author Report Posted October 22, 2012 I've been running them for a while now. They are a giant step-up from my ported stock jugs but I'm lazy. It's not always a drag race when I ride. I might sell them for something else. Quote
pabansheematt Posted October 22, 2012 Report Posted October 22, 2012 I've been running them for a while now. They are a giant step-up from my ported stock jugs but I'm lazy. It's not always a drag race when I ride. I might sell them for something else. The 4 mill version has zero bottom end or mid range. Quote
Paulie B Posted October 22, 2012 Author Report Posted October 22, 2012 (edited) The 4 mill version has zero bottom end or mid range. I have to get my bigger carbs on. I still have stockers on but it has the same bottom end as my old combo with a ridiculous top-end. I'm easily entertained I guess. I'm running wht I call an all stock combo. Stock head, reeds, carbs, airbox..... It's still a pretty fun ride. Edited October 22, 2012 by Paulie B Quote
