So i did a plug chop today and i have no experience with this at all so i was hoping some of yall could tell me what my motor is trying to tell me
Take pics of the other side of the plugs too. ( flip em over)
Well i didnt think to do that and i already left the farm but the other side has a brown ring around it just like you can see on the edge of the plugs i will takes pics tommorow
I took pictures of the other side any help is greatly appreciated
looks like it is slightly rich to me. not by much.
i should have said this first: you should post up some details of your combo (i.e. engine size, jet size etc) and your elevation.
Edited by dozer
Is it normal for it to have that spot on one side of the plug like in the first pics that i posted up
Its really hard to start sometimes until its warmed up then it fires right up
My setup is
Toomey t5s
Stock carbs 320 main 27.5 pilot
Uni air filter no lid on the air box and the box its self is drilled and cut its just there to keep dirt down
Cool head 20 cc domes
Stock cylinders with F.a.s.t clean up port
V force 4s
Boost bottle
+4 timing
I think thats every thing
And my elavation is about 900 to 1000
stock stroke? how many turns out on the air screws? when my plugs looked like the first pics you posted i was 2 or 3 sizes too large on the main.
320 sounds rich. i was at 290 with pods on my old setup but i didnt have any portwork.
Well I have a 300 I can put in and try should I order a bigger pilot jet considering it's hard to start what else would cause it to be hard to start
The choke not closing all the way. Bad reeds. Not useing the choke properly. Carb sync.
The choke im not sure of but the reeds are two weeks old v force4s
Possibly a carb sync but it runs good on top end idk if it would make a difference or not.
  • 2 weeks later...
1. clean carbs good all jets and holes even clean out the choke.
2. sync carbs.
3. turn a/f screw 1.5 out.
4. needle middle clip.
5. keep in 320 even though that sounds a bit rich.
do another plug chop.
your going to need more jets! but do another plug chop to see, make sure you go threw all the gears and rev it out good! .
being hard to start when cold might be due to compression, how old is the topend and have you done a compression check?
  • 2 weeks later...
