Dahl87banshee Posted September 30, 2012 Report Posted September 30, 2012 Was riding around the other day and my left peg ripped out. The rear bolt still has OK threats but the front is ripped right out. I got longer bolts for the nerfs like needed so that wasn't the problem. What should I do? Tap it with a bigger size or? I don't want a quick fix It needs to actually last. Hopefully someone can shoot me in the right direction. Quote
joey83 Posted September 30, 2012 Report Posted September 30, 2012 Tap it or drill all the way through and put a nut on the back side of frame. might be ugly though. Quote
locogato11283 Posted September 30, 2012 Report Posted September 30, 2012 There are a couple fixes for the foot peg area.. 1. You can use all thread in the rear. Drill out both sides and run a piece all the way through and put a nut on the outside of the pegs. 2. Have a machine shop cut you inserts. Cut out the old ones and weld in the new ones. (This is what I do) 3. Drill out and go tap a bigger bolt. Quote
Dahl87banshee Posted September 30, 2012 Author Report Posted September 30, 2012 I like the insert idea. I'll see what I can find for a good machine shop around here. Thanks for the ideas. Quote
Phelps Posted September 30, 2012 Report Posted September 30, 2012 i had stellar cut me some inserts. Quote
notsed Posted September 30, 2012 Report Posted September 30, 2012 just fixed mine with some of these, worked great but they have a 1.5 pitch thread http://www.ebay.com/itm/M6-M8-M10-M12-RIGHT-LEFT-HAND-Threaded-Insert-Tube-Adaptor-Rose-Joint-Inserts-/270981606014?pt=UK_SportingGoods_OtherSports&var=&hash=item3f17c32a7e Quote
possum Posted September 30, 2012 Report Posted September 30, 2012 just get a nut and countersink it and weld it in. looks just like factory. ive done several like that. cheap and easy Quote
