Here's what I got ...
New hot rods crank
Bored .30 over
Vforce reeds
Fmf full exhaust
Toomey 2 into 1the intake
30 pilot 280 main
Tors delete
Boost bottle
Wiesco lite pistons
150psi in both sides
Carb screws are 1 1/2
Br8es
Carbs synchronized
94 pump gas mixed 40:1
Im at sea level
Whole thing rebuilt 2 hours ago
The problem
Very hard to start
Left cylinder cuts out under part throttle buts fine on idle and wot.
Trying to figure out where to start
id check caps and coil to start .30pilot seems abit fat.prob not your issue but imo id go down to a 27 1/2. im guess you have duel carbs and a 2 into 1 filter set up.it would' nt be hard to sync a 2 into 1 intake . goodluck
Choke tube is inplace.
Si I switched the plug wires from one side to the other and it got better was ut still not 100%
That doesn't make sense. They fire at the same time. If the wire or coil was bad shouldn't the problem switch sides?
