Hi i have 01 Banshee
with this mods
Bored 1 size over
FMF Fatty
K&N with no lid pro flow adapter
Stock carbs with no tors (sinked) and with idle screws
elevation 400ft
stock pilot jets
Mains are 280
1 1/2 turns on mixture screw
Starts Right up,
but idles oK only on choke
If i screw in the idle screws it starts reving
When I hit on throttle it stumbles first and then revs.
MIDDLE Rev is fine but seems stil not powerfull enough
Once in three time about After letting go off throttle it doesn't drop the RPMS right away
Help please I think I need to down jet it.
With your current jetting...running the lid on the airbox with vents installed about 12...would probably be spot on...
Sounds lean.. try a 27.5 or 30 pilot... 310 main.. clip for the needle in the middle... jmo
I am trying to get jets
But even al jet kits don't sell all stuff i need
I was told that the motor runs rich oposite but the idle is lean
What you think about this
  • 3 weeks later...
I have the same mods (except for the overbore) on my 06 & at 480ft in MN i ran 240 mains & stock everything else on the stock carbs w/o tors & it was perfect. as it happens i had similar idle & rpm 'stick' problems too, it turned out my needles were bent at the tips... replaced em & it was 100%. maybe go 250 or 260 on the mains for overbore? hope that helps.
The pilot jet handles from 0- 1/8th throttle
The needle handles from 1/8-3/4
And the main jet handles from 3/4 on......
That being said FMF pipes really like 27.5 pilots. the main being around a 280ish seems decent.....maybe 290 if you have pod filters.
The reason it is not coming down smoothly and quickly to idle is because it is starving for fuel........remember......2 strokes will free rev or rev hang when they are run lean on fuel.
You can order jets online or from our site sponsors.........watch out though....while I've found mikuni main jets at snowmobile stores that will work in the stock carbs.......the pilots are banshee specific.....
