Justintoxicated Posted October 16, 2003 Report Posted October 16, 2003 after I cahnge my air filter and pipes, and jets (320's I think: it was 10 sizes higher than the number on the stock ones it comes with) I had to remove my airbox lid. The bike idles fine with it on, but bogs and hesitates with the lid on. Have you tried removing the airbox lid? Quote
sheebroke Posted October 17, 2003 Author Report Posted October 17, 2003 (Did you run your shee wide open in 6th gear?)...yes i did what benbb's site said to do (plug chop) . (make sure the choke tube is in place between the two carbs (1/4" x 2" long), ) yep thats 1 of the first things i checked . (Make sure your slides aren't backwards) nope they are in right the notched side u can c throw the air box.(Did this all start at once or after you changed something????) the bike ran and ideled when i got it back from the shop fired up first kick ... it jus never ran that well on the top end 1 cylnder would quit (right side) thought it was reeds they looked fine could use new 1's . all the sudden it wont start when kickin it (no fire ) but if u pull it it will fire right up . it seems the more i ride it the better it runs ? but i dont want to have to pull it everytime i want to ride after riding it will fire up first kick and sometimes it wont. (no fire ) as for the air box lid i have ran it with out and still the same . i'm thinking its the stator but just want some advise befor going and buying a new stator . thanks again guys i really cant thank u enouph for all the replys . im going to try and get a new stator this weekend and c if that fixes the prob. thanks jeff Quote
Banchetta Posted October 17, 2003 Report Posted October 17, 2003 (Did you run your shee wide open in 6th gear?)...yes i did what benbb's site said to do (plug chop) . (make sure the choke tube is in place between the two carbs (1/4" x 2" long), ) yep thats 1 of the first things i checked . (Make sure your slides aren't backwards) nope they are in right the notched side u can c throw the air box.(Did this all start at once or after you changed something????) the bike ran and ideled when i got it back from the shop fired up first kick ... it jus never ran that well on the top end 1 cylnder would quit (right side) thought it was reeds they looked fine could use new 1's . all the sudden it wont start when kickin it (no fire ) but if u pull it it will fire right up . it seems the more i ride it the better it runs ? but i dont want to have to pull it everytime i want to ride after riding it will fire up first kick and sometimes it wont. (no fire ) as for the air box lid i have ran it with out and still the same . i'm thinking its the stator but just want some advise befor going and buying a new stator . thanks again guys i really cant thank u enouph for all the replys . im going to try and get a new stator this weekend and c if that fixes the prob. thanks jeff I wouldn't buy a stator yet. Usually a stator will either work or not. I'm thinking a bad connection. Check the orange and black wires on the coil under the gas tank. Make sure the connection is tight. Check the plug caps and make sure you have a good connection. Try swapping coils from a friend to see if your coil is acting up. Also disconnect the black/white striped wire going from the kill switch on the handlebars to the gas tank. There is a single connection, disconnect it. That'll bypass your kill switch on the handlebars. Those switches tend to fail. Quote
sheebroke Posted October 18, 2003 Author Report Posted October 18, 2003 got ya ill check tomorrow . i hope it is somthing easy like that ty again Quote
sheebroke Posted October 20, 2003 Author Report Posted October 20, 2003 well i had time to sit and mess with my shee today check everything cleaned crabs again checked all the wireing all was good . i kicked it about 10 times no fire so i then pecked on the cdi box with a screwdriver and 1st kick fired right up ! so i got a cdi box from a buds parts bike and shee ran like raped ape woohoo i cant thank u guys enouph for all the replys u guys are the best . now i need new plastic and other minor parts . i also learned that u dont let ur buds ride ur shee all the damage on my bike is from a buddy ridin it ( first time banshee rider ) he ended up with 17 stiches in his tounge oouch ! so im back in busness gonna get some new exhaust prob DMC 916 or dynoport 2:1 . hope to make it to lil sahara OK soon thanks alot guys . would anybody mind if i put a www.bansheeHQ.com sticker on my bike ? thanks again . jeff lebanon MO Quote
