i resently got a 99 banshee it has 156 pounds of comp. cool heads boot bottle, fmf pipe stock gears and 20in back tires and my buddy has a 2000 all stock banshee well it has fmf header and yoshemira tail and it has more get and go than mine what do i need to do ????
Rid yourself of that stupid boost bottle and tune the carbs. In fact, just do a tune up in general. While its possible he might just be a better rider, it could be mechanical such as slipping clutch, air leak, incorrect jetting, fouled plugs, ect....
i had a guy tell me to smash the boost with hammer lol
and its not that he is a better rider i can ride his and feel the difference and i had tuned it infact his didnt run and i tuned it also now it runs better than mine
Edited by jimmymichael
Other than double checking the sprocket counts and jetting, air box lid or not, etc., I wouldn't believe there would be a noticable difference from pipe brands, I notice mine looses a ton of bottom end when the pipes need packed.
i counted sprocket and tire size tonight and they are booth 14/41 and 20 inch tires and his is all stock jetting and mine is 30 pilot and 330 main i think id have to double check the main also his has no packing in and my packing is good and his has fatory air box and mine has k@n
you are right
330/30 is pretty big for just fmf pipes.
now if he has pods and maybe reeds those numbers would be better.
it has boyesen reeds in it also k@n pods but i will for shure try different jets and also i live on Iowa Missouri bourder if that helps with elevation any ??
