yamahaty Posted July 14, 2012 Report Posted July 14, 2012 HI guys please help me im going on a big 3 day ride in 2 weeks and my throttles are sticking. I have taken the carbs completely apart Two ties now and they still stick. Both carbs are completely spotless but i cant figure this out. Can it posibly be reed problems, Please help guys. Anything will be appritiated, Thanks. Quote
sheerider11 Posted July 14, 2012 Report Posted July 14, 2012 Are the slides sticking?? Or are the rpms hanging? Quote
yamahaty Posted July 14, 2012 Author Report Posted July 14, 2012 Are the slides sticking?? Or are the rpms hanging? Im not exactly sure the slides are smooth as can be. When im riding it i let off and it stays as if i was at 1/4 throttle and sometimes it will stick around 3/4 to full throttle and i just shut it off then i fire it back up and it will be ok till i let off the throotle again and it does the same. But like i said the carbs are spotless. Quote
Nightmare Posted July 14, 2012 Report Posted July 14, 2012 Pull the slides. Mine did the same thing, felt smooth as butter but as soon as i pulled them i found grains of sand on them. Cleaned them up and had no problems after that. Quote
Paulie B Posted July 15, 2012 Report Posted July 15, 2012 This might be a stupid question but have your lubed your cable recently? Quote
thomas h. Posted July 15, 2012 Report Posted July 15, 2012 Also test cable. Remove throttle and just move by hand. If it sticks possible new cable or maybe the way the cable is routed. Quote
Remus Posted July 15, 2012 Report Posted July 15, 2012 Yip, ill bet you its the cable, pulled mine of today, sometimes it stuck at full throttle, sometimes at idle, it only takes n dry cable guide or broken strand on the cable to make it stick. Quote
BrockMoto Posted July 17, 2012 Report Posted July 17, 2012 Check the cable, and make sure its oiled too, dirty slides are what usually cause this tho I'd check em again and if they are dirty check your filter for rips Quote
