thesoultaker2117 Posted July 14, 2012 Report Posted July 14, 2012 I came across a good steal on a polaris 600 triple. Was wondering if anyone has ever messed around with these and what my options would be for turning it into a full drag quad.....help anyone Quote
585 twister Posted July 14, 2012 Report Posted July 14, 2012 what would u like to know, i can help u with the whole build. mines a slp 707 pushing 140 to 150hp there fun. Quote
thesoultaker2117 Posted July 14, 2012 Author Report Posted July 14, 2012 Anything you can tell me. Where to get a jack shaft. How good are these rotary valve induction motors compared to reed induction. Quote
585 twister Posted July 15, 2012 Report Posted July 15, 2012 there good motors all about the same in power..the jackshaft i ended up haveing a mechine shop make a chromoly one ,used a stock keyway for the secondary clutch, then another keyway for the front sprocket, turned down a coupler they sold and turned out a sprocket and welded them. but u need to figure out were the motor will sit and the jackshaft will sit then u can measure from center of of jackshaft to center of front clutch or crank to find a belt to fit correctly any snowmobile shop can cross reference the mesurment. and make sure ur secondary clutch will have the room for belt deflection and can open up without hitting the frame..sound fun..oh ya u can ues the stock jackshaft bearings also.. Quote
thesoultaker2117 Posted July 15, 2012 Author Report Posted July 15, 2012 Now not just for the chassis set up...i have that pretty well under control. Building this motor. Best ways to make power. I know these 38and mikuni roundslides have to go. Same with the 3 into 1 pipe. Other than buying actual aftermarket pipes for it.....what could i do there. Porting...port durations....rotary valve intake durations. I dont know where to start. You can shoot me a text. 8145058437 Quote
