my current set up is dune port, 21cc domes in cool head, stock carbs, pro lite pistons, pc pipes, no airbox lid, pro design pro flow filter, vf3 reeds, +5 timing, i want to know what would get my motor to perform at its full potential. its a trail/ race bike. thanks in advance
who ported it? where do you want more power at? mx race or dra race?
Edited by toytech
kevin herr did the dune port. and its my trail bike, but i drag race my friends all the time. so it cant be a hardcore drag bike
Shearers or CPI or snipers will be the pipe choices.
Have you considered a sneaky Pete nos system? Or straight cut gears( worth alittle hp)? Also a duneable overide is super fast because you will not have to let off the gas but it is a trail bike the maybe a end cut tranny mod some ppl speed shift and don't touch the clutch and only let off alittle.
Somtimes spending money on hooking up good is worth it because you will put more hp to the ground.
Also make the bike/rider on a diet
Blend your gas
Non o ring chain
Perfect jetting
Since you will ride mud cut part of the air box off and add circle filters near the bottom of the box next to filter
Get compression little higher
Skilles are cheap
Cdi box that revs higher
How's your bike set up? If your not getting the power to the ground or can't keep it consistent then you are wasting your time. How's your clutch? Are you using stock suspension? What gearing do you have? Your trail riding, you want in frame drag pipes, you want bottom end , and seems like you want 100 mph out of your bike. You just want it all don't you. Someone with a smaller motor can beat you any day as long as there bike is set up right. Try that if you haven't and see how much faster you get.
my jetting is perfect, spot on. no bog at all.
asfar as putthing power to the ground, i have a +4 swingarm with 22" holeshot XCTs, it hooks right up.
i have a barnette clutch in a hinson billit basket.
up front i have brandnew fox floats. and my rear shock is set up for my weight (200lbs).
my gearing is 15/40.
does that answer all your questions?
i dont want it all, i dont expect 100mph. i expect the most horsepower i can get out of my motor the way its setup, just by better bolt ons.
when i said i want drag pipes, i want them to make me more power, i know its going to get rid of some of my bottom end but i didnt want a pipe thats gonna kill all my bottom end.
Send it back to get ported for a 4 mil and get the crank. Get a adjustable pipe
