I also had a problem sealing this ADA head. I bought mine off ebay. I even tried buying all new new seals. The only way they sealed was with a little silicone. Just send back the head and get your money back and buy a noss head or a pro design and forget about any problems..
I have a pro design head and have been fighting a leak problem myself. It likes to leak out of the head studs. New o-rings don't fix it either. IMO the head design is the problem. The head shell should be 1 piece instead of 2 pieces and it should use a stock head gasket instead if o-rings, so the bastard doesn't leak. I fixed the problem by throwing away the pro-design.......I mean poor-design head and machining a stock head and using that. A friend of mine tested between a stock head and pro-design head and the pro-design only dropped coolant temp by 2deg. Not enough to justify any benefit. I understand your head is a Ada head and mine is a pro-design, but I would remedy the situation with the use of a stock machined head.
I'm leaning toward that myself. I can't return it because it's been over 14 days since I received it. So I hoping to get it resolved because I'm almost tapped out from the build. Started from scratch.
If you paid via Paypal you can open a disput and he will have to refund your money or come to some sort of resolution. And trust me he will try to fix the problem as paypal will remove the money from his account and keep it in trust unti'll the disput is solved. If you use paypal the ball is in your court. You have 30 days so Giddy-up.
It's been over 30 dys. I contacted them and explained that it was leaking and that I checked level and straight edges them and still leaking. They said even if the cyls are out a ten thousandth of an inch it would leak. Wtf. For real?
Is it leaking into the cylinder, or out of the top of the head? Where exactly is the leak? If its getting into the cylinder, you can resurface it by running it over fine sand paper laid over a piece of marble or glass. If its leaking around the studs, just put some yamabond on the studs.
