Si i need a brake light for the dunes having trouble figuring out how to wire one in. Doesnt seem to have a brake switch which im a little confused on. What should i do harness looks a little hacked up nothing major though.
What year is it? only 2003+ had brake lights. The rest just had running lights.
87 i was reading on the site i will have to change my harness to a newer one to accomidate the switch.. is thia true?
Do you HAVE to have a brake light, or just a running light? If you upgrade your harness, you'll also have to upgrade your your stator to the newer style plug, or splice it in. I would just get a switch off of a newer model, and a brake light off of a newer model, tie into the chassis ground, and the power between the stator and headlight switch.
