Need some for a replacement. My handlebars and wheels have a lot of play in them. Also, need some AM upper and lower A-arm ball joints. Need some for under 50 if possible.
Edited by RACxEMxWILLIE
A arm ball joints aren't replaceable.
Are you sure that you a arm joints are bad? Really if you only have steering slop its probably just the tie rod ends...
you can pick just the ends up for under $30 and you might as well replace them steering stem bearing while your down there its about $12
Awesome. They had a little play in the wheels from side to side and knew that was the tie rods. I actually didn't check the upper and lower ball joints. I actually didn't know they couldn't be replaced. Thanks for the heads up.
he has aftermarket arms
