Hi guys I got a 421 cub with 34 mikuni flatside carbs setup up for methanol. Runs ok until about a third of a throttle, after the powerband hits it boggs, do you guys think that I need more fuel or less fuel, spark plugs are a little wet. Any information will be helpful. Thanks
I would feed it and see what it does.
I raised the needle up all the way and it still doing the same thing. I'm going to install a pvl ignition soon and see if its my stock ignition. Thanks for the reply.
  • 4 weeks later...
prolly rich....
  • 4 weeks later...
If its bogging on topend it's probably too much fuel loading up in the cylinders and not being burned off. What's your setup and what size jets are you running? Did this just recently start to happen or is this after a major change or rebuild?
