BigRed350x Posted June 10, 2012 Report Posted June 10, 2012 Good set of Un-Stamped CPI in-frames. Chromed. Got these from hp2000 just a couple days ago and like the big-bore shearer's I have on the cheetah more. There is one upper hanger that has a crank in it. Other than that these are in good shape, nice and clean. I can weld the crack up before shipping, or I can ship them as they are, you're choice. The pipes are still wrapped in the plastic they were shipped to me in. Small-Bore, In-Frame's, Chrome, unstamped $400 SHIPPED Quote
yzrmbsg Posted June 10, 2012 Report Posted June 10, 2012 Damn, i want these bad! Sent using Tapatalk! Quote
mopar1rules Posted June 10, 2012 Report Posted June 10, 2012 What's the deal with unstamped CPI's? Did they have stamped versions that sucked or something? Quote
BigRed350x Posted June 10, 2012 Author Report Posted June 10, 2012 Damn, i want these bad! Sent using Tapatalk! So buy them. Quote
BigRed350x Posted June 10, 2012 Author Report Posted June 10, 2012 What's the deal with unstamped CPI's? Did they have stamped versions that sucked or something? The un-stamped ones don't have the CPI logo on them anywhere. They have the same level of performance, just a lot cleaner look on the bike. - Jared Quote
Bkm2006 Posted June 10, 2012 Report Posted June 10, 2012 cant tell from the picture, is the crank in the base metal? all the way threw? welding it would ruin the chrome on the hanger tab... .. im interested Quote
BigRed350x Posted June 11, 2012 Author Report Posted June 11, 2012 cant tell from the picture, is the crank in the base metal? all the way threw? welding it would ruin the chrome on the hanger tab... .. im interested CPI mounts are two pieces of metal welded together, the crack is only on the front piece of metal, and is only up on the tab itself. There is no cracking on the pipe's expansion chamber. The hanger tab would be the only thing affected if it were welded up, and on most bikes the hanger tabs are not seen unless you are kneeling down next to the bike. A professional shop could TIG the crack with very very little heat discoloration on the chrome on the tab. -Jared Quote
BigRed350x Posted June 11, 2012 Author Report Posted June 11, 2012 Trade u 4 big bore CPI No thanks Just FYI... the expansion chamber on big bore and small bore CPI's are identical, the only thing that is different is the diameter of the stinger tube. You could easily convert your big-bore CPI pipes to small bore CPI's with just a stinger-tube change-out. - Jared Quote
yzrmbsg Posted June 11, 2012 Report Posted June 11, 2012 I am fighting the urge, dammit I want these bad! Sent using Tapatalk! Quote
yfz235 Posted June 11, 2012 Report Posted June 11, 2012 I am fighting the urge, dammit I want these bad! Sent using Tapatalk! Do it!!!!!!! But you will loose a lot of bottom end... Yours pulls really hard as it is. Sent from your mothers rancid vagina using Tapatalk! Quote
yzrmbsg Posted June 11, 2012 Report Posted June 11, 2012 Do it!!!!!!! But you will loose a lot of bottom end... Yours pulls really hard as it is. Sent from your mothers rancid vagina using Tapatalk! Shut up Bitch, you are not helping! But I could put these in mine, and then use the FMF's for the gf's build! Decisions decisions! Sent using Tapatalk! Quote
yfz235 Posted June 11, 2012 Report Posted June 11, 2012 Ha ha ha buuuuut you saw how mine pulled and ran. Your top end will scream.... And the unstamped look so much better. You will need them anyways... Buy them!! Sent from your mothers rancid vagina using Tapatalk! Quote
