im messing with the clutch in my dune/play port banshee. i ride mostly trails, lots of road riding (wfo 6th gear alot) and friendly drag racing.
im upgrading my clutch, and primary gears. what do you guys think is best? i plan on getting my parts from f.a.s.t.
just wondering what the experts say.
I run the Hinson spring-loaded billet basket with straight-cut gears in both of my quads. The drag bike has an 8-plate full hinson clutch setup and the cheetah has the spring basket and stock inner hub and stock pressure plate. Both bikes run a direct-drive lockup & 12-bolt cover. I love the clutch setup on both and would highly recommend the spring-loaded basket if you can afford it.
This is the same setup I run in my drag bike.
http://www.ebay.com/itm/Banshee-Hinson-Clutch-Basket-Cut-Gear-Hub-Pressure-Pla-/250592552822?pt=Motors_ATV_Parts_Accessories&hash=item3a587ae776&vxp=mtr
Here's a used spring basket for a good price.
http://www.ebay.com/itm/Banshee-hinson-spring-loaded-clutch-basket-w-straight-cut-gears-billet-drag-race-/160815934674?pt=Motors_ATV_Parts_Accessories&hash=item2571606cd2&vxp=mtr
- Jared
- Jared
thats a little more than my budget. i know im going with a barnette dirt digger clutch. i have no idea what springs, or basket or anything else
Just get a tusk clutch with the hd springs. Cheap and they are a good clutch. If you cant afford straight cuts, then stock helical cut gears are your only option. Straight cuts are around 300. And a billet basket will be 150-250 depending on brand.
Jared
