BLOODRAGE Posted May 21, 2012 Report Posted May 21, 2012 just checked my plugs last nite and the pto side seems to be leaner then the flywheel side.im at 340 on both so i was thinking about uping the pto side to 350,would that be normal? Quote
Surfrjag Posted May 21, 2012 Report Posted May 21, 2012 check your float height on both carbs. are you running pods? maybe one prefilter is clogged some? have you done a leakdown test to be sure its not from a small airleak? Quote
BLOODRAGE Posted May 21, 2012 Author Report Posted May 21, 2012 i have the single k&n filter.ive heard on sled forums on tripples they had different jets on the pto side.my boss's sled is the same way so that gave me the idea.besides that the motor runs as it should.im going to try it and see what the shee thinks of the different jet sizes Quote
sheerider11 Posted May 23, 2012 Report Posted May 23, 2012 Sounds like your trying to compensate for a leak. Do a leak Down test. Quote
BLOODRAGE Posted May 23, 2012 Author Report Posted May 23, 2012 found the problem i think,i wont know till i get new plugs.i had to drop the needle one clip.i was drowning the motor with 340 on the middle clip.the silencers were always wet with oil Quote
