01yamban Posted May 16, 2012 Report Posted May 16, 2012 What's the best way to kickstart a banshee? When it's cold I pull the choke but do I hit the throttle? Does my idle setting have any thing to do with how it will start without hitting the throttle? I know my idle was a lil set a lol high Quote
ClayAiken Posted May 16, 2012 Report Posted May 16, 2012 What's the best way to kickstart a banshee? When it's cold I pull the choke but do I hit the throttle? Does my idle setting have any thing to do with how it will start without hitting the throttle? I know my idle was a lil set a lol high I pull choke all way out and whack throttle once. only go to about 1/4 though. Quote
special06shee Posted May 16, 2012 Report Posted May 16, 2012 Just kick it like it stole something from you!!! Quote
wfobasheeboy Posted May 16, 2012 Report Posted May 16, 2012 WOW 3 post for no start when cold. How do the plugs look after you kick the shit out of it? Could use more INFO on set up. Quote
01yamban Posted May 16, 2012 Author Report Posted May 16, 2012 So u whack the throttle while kicking it over? It's weird it will fire up instantly if I roll it down my driveway and dump the clutch in 2cd gear Quote
Dicklez Posted May 16, 2012 Report Posted May 16, 2012 You must not read the reponses on your other threads. Have you checked your compression yet. Quote
01yamban Posted May 16, 2012 Author Report Posted May 16, 2012 The Plugs look ok to me after kicking over alot, I figured they would be sloppy but they were barly wet. It's got fmf gold series with fattys, proflow billet air intake, air box with no lid, boost bottle,the not sure about the reeds they are black you can't see threw them and they look to be carbon fiber, sea leval, 290 mains, 27.5 pilots and air screw 2 turns out at the moment gonna turn th back to 1.5 and see how she runs. I do have a issue with it leaking gas out the overflow hoses at the bottom of the carbs when done ridin it I have to shut the gas off or it will drop. Oh and it's not bored out stock piston/ head Quote
01yamban Posted May 16, 2012 Author Report Posted May 16, 2012 Nope I haven't but that will be next, gotta get a tester I guess, I was hoping I was just doing something wrong with hitting the throttle while kicking or something Quote
Finch Posted May 16, 2012 Report Posted May 16, 2012 i get on mine no choke no throttle kick it once and it starts. as said read your other threads before ya just keep making new ones me and dicklez both mention comp Quote
ticktock Posted May 17, 2012 Report Posted May 17, 2012 On your carbs there is an air screw. Small gold left side of the carbs. On the left carb turn that screw in until it lightly seats (snug, dont tighten). While your screwing this in count the turns, normally this is done in quarters. Ideally you would like to be between 1-1 1/2 turns out. Depending on mods, your pilot jet could be too small. You can compensate this with the air screw. This will cause the bike to start hard when cold. You must adjust both carbs the same. I recommend counting the turns out and setting the carbs 1/2 turn in. Adam Quote
wfobasheeboy Posted May 17, 2012 Report Posted May 17, 2012 The Plugs look ok to me after kicking over alot, I figured they would be sloppy but they were barly wet. It's got fmf gold series with fattys, proflow billet air intake, air box with no lid, boost bottle,the not sure about the reeds they are black you can't see threw them and they look to be carbon fiber, sea leval, 290 mains, 27.5 pilots and air screw 2 turns out at the moment gonna turn th back to 1.5 and see how she runs. I do have a issue with it leaking gas out the overflow hoses at the bottom of the carbs when done ridin it I have to shut the gas off or it will drop. Oh and it's not bored out stock piston/ head On your carbs there is an air screw. Small gold left side of the carbs. On the left carb turn that screw in until it lightly seats (snug, dont tighten). While your screwing this in count the turns, normally this is done in quarters. Ideally you would like to be between 1-1 1/2 turns out. Depending on mods, your pilot jet could be too small. You can compensate this with the air screw. This will cause the bike to start hard when cold. You must adjust both carbs the same. I recommend counting the turns out and setting the carbs 1/2 turn in. Adam Sound like your jetting is very close to spot on. My old set up was very close to the same as yours. I was 300 on the mains with 27.5 on the pilots. But I was about 1 to 1 1/4 turns out on the air screws. So if the plugs are not wet I would do like POW said & turn in the air screws about a 1/2 to 3/4 and try that. Good luck & keep us posted. Quote
01yamban Posted May 17, 2012 Author Report Posted May 17, 2012 Thanks bud, I went out today pulled the choke kicked it a few times without hitting the throttle,then I think I let off the choke and kicked it a couple more and it fired up drove it about 6 miles around town, ran awesome, came back let it idle, idle mite be alil high not sure if that effects how it starts or runs but it idles great. Shut it down and 1 kick it will start every time when warm. I still gotta do my comp test but I'm going out and adjust the air screws like u said and see what that does when it's cold was u near sea leval also? Quote
Coupelx Posted May 17, 2012 Report Posted May 17, 2012 Choke works better with the throttle closed. Quote
