Well , My bike will be down longer than expected , my cylinders and head need machine work and it's gonna be to the tune of 580.00 . No biggie , just money but puts a hold on riding for a bit longer . I'm thinking about getting that relocator bracket for the CDI , Reg and Coolant bottle . I was reading that it attaches with self tapping screws into the frame? I don't want to weaken the frame , It appears where it mounts that it doesn't look like it would compromise anything . Anyone run one? I'd also like to run the tail light wires inside the frame tubing . Anyone do this ?
Thanks for considering the bracket.... It does work well and myself and my local buddies have had zero issues with them. The self tappers are very small, I would worry about weakening the frame. Brackets come with all hardware needed to install. You must also be running braided front brake lines to use this bracket. If you get it powdercoated do not forget to grind a spot so your V reg can ground.
-JD
Anything and everything JD offers is top notch. I would not worry about a thing regarding the frame , you'll be more than happy.
