DDShee Posted April 28, 2012 Report Posted April 28, 2012 My banshee wont run right. Runs okay until i get into the powerband then it starts to spit and sputter. Also drip gas out of the drain on the bottom of the carb bowl. Any help is appreciated. Quote
DDShee Posted April 28, 2012 Author Report Posted April 28, 2012 has aftermarket pipes, cool head. Quote
6mil'ster Posted April 28, 2012 Report Posted April 28, 2012 has aftermarket pipes, cool head. buckwheats dad should have jacked off the night he was conceived Quote
RadarRacing Posted April 28, 2012 Report Posted April 28, 2012 Your needle and or float is probably sticking and overflowing the carb and giving it too much gas making it run very rich on at least that one side. Fix the overflowing problem and your running problem will probably go away. Quote
DDShee Posted April 28, 2012 Author Report Posted April 28, 2012 buckwheats dad should have jacked off the night he was conceived that has nothing to do with my queston so you can leave Quote
DDShee Posted April 28, 2012 Author Report Posted April 28, 2012 Your needle and or float is probably sticking and overflowing the carb and giving it too much gas making it run very rich on at least that one side. Fix the overflowing problem and your running problem will probably go away. okay i will try cleaning my carb tonight, thanks for helping, unlike some other people. Quote
DDShee Posted April 29, 2012 Author Report Posted April 29, 2012 cleaned the carb, its a little better, but still not perfect Quote
2004LEBanshee Posted April 30, 2012 Report Posted April 30, 2012 The spit and sputter could be a lot of things.too rich on the main or needle bad spark ect. The gas dripping is either your float isn't adjusted correctly or your valve seal is bad. Quote
bluebanshee98 Posted April 30, 2012 Report Posted April 30, 2012 air filter type? air box? lid on or off? what elevation, temp? what size main jets are in the carbs? this will help with the correct jetting Quote
