My banshee wont run right. Runs okay until i get into the powerband then it starts to spit and sputter. Also drip gas out of the drain on the bottom of the carb bowl. Any help is appreciated.
Your needle and or float is probably sticking and overflowing the carb and giving it too much gas making it run very rich on at least that one side. Fix the overflowing problem and your running problem will probably go away.
buckwheats dad should have jacked off the night he was conceived
that has nothing to do with my queston so you can leave
okay i will try cleaning my carb tonight, thanks for helping, unlike some other people. :headbang:
