what is better ? (fuel mix)
jack2012
24.1 is just more rich. I have always ran 32.1 with no problem. It's a little more lean so maybe its a small power difference, but I don't think it would make a noticeable change. Just run whatever your bike was broke in with and have fun ::cheers::
The better the oil, the less you need to run. I run Klotz R50 at 40:1 in my Banshees, have ran that way for over 20 years and have had NO problems, get pretty good life out of topends and everything is well lubed when I tear them down to inspect and freshen up.The less oil you have in there means it is less likely to foul spark plugs and the more fuel you have to make power.
You mix to the oils requirements. If the oils says to use it at 20:1...then mix it at 20:1. If the oil says it can be mixed at 40:1...then mix at 40:1.
If it's Amsoil and it says you can mix it at 100:1.........I'd think about that first. :lol:
