there is no rectifier.. just a voltage regulator.. 12-14v AC.. u can dloat the ground on the stator and ad a rectifier to convert to 12v dc if you like
how do i convert it over to DC.... is there instructions to do this anywhere.... i got me a set of nice LED headlights off a forklift that are nearly identicle to the stock lights
Correct. Typically an unregulated stator puts out 37-40VAC at WOT, 7-9VAC at idle.
thats cool i just need to know how i convert it from ac to dc current.. the lights i have are 12 volt dc
the stator is capable of 40+ vAC if unregulated.
Yea it is pretty cool when you forget that you un hooked the regulator and you give it a rev with the headlights on. Nothing like having a set of PIAA H6M Bulbs going off like one time use Flash Bulbs.
Haha, BUT, they were bright for a split second before they blew, right?
