WynoT Posted April 16, 2012 Report Posted April 16, 2012 Hi, i'm currently building a 4mill longrod with 65.50 bore stock cylinder and a light port job. I have a squish band between 0.070 & 0.080 is it right ? Thanks Quote
WynoT Posted April 16, 2012 Author Report Posted April 16, 2012 Ok thanks for your fast reply I currently using the thick .080 head gasket cause I cant find any coolhead stroker dome anywhere.. Nor ebay than TDR.. If you know place that sell them I would be pleased to know it.. It was on my plan to bring my stock stroke dome to a machine shop to be machined 2mm deeper cause I know the thick head gasket is a shitty way to built it... Quote
WynoT Posted April 16, 2012 Author Report Posted April 16, 2012 Yes I have a 4mill longrod crank and there is a thick .080 head gasket sold at Bansheedepot.com that give the extra clearance to the head chamber to run your stock head or stock dome without milling but it's also true that it's a shitty way to built a 4mill so i'll get my dome cut tomorrow Thanks for the help I order this plate cause I wanted to test it and see how it goes but when I take my squish this morning I thought it was way too much so I get scared and ask here Quote
ticktock Posted April 16, 2012 Report Posted April 16, 2012 Call Wildcard or fast tell them what you have and for like 80 bucks you can get domes Quote
BigRed350x Posted April 16, 2012 Report Posted April 16, 2012 Kevin @ HJR can cut you a set of domes for your setup. Give him a call. His number is in my signature. - Jared Quote
