steve14733 Posted April 13, 2012 Report Posted April 13, 2012 can some one tell me if i need a special head gasket other then the one i got from vitos with ther super stock piston kit. also got the new o ring kit from noss.. its a 64.50 bore and a noss head with 20 cc domes hot rod crank stock stroke. also im gonna get rid of they single carb set up . i have lectrons 38s they would be too big though i think ?? what size carbs would i run for fast trail riding,,were at 1650 ,,also am i pushing it with the 20cc domes on pumpgas. i dragrace and build 4 cyl dragbikes, kinda out ov my comfort zone with the 2 stroker any help will be apreciated.. steve http://tinypic.com/r/erz8fl/5 Quote
steve14733 Posted April 13, 2012 Author Report Posted April 13, 2012 can some one tell me if i need a special head gasket other then the one i got from vitos with ther super stock piston kit. also got the new o ring kit from noss.. its a 64.50 bore and a noss head with 20 cc domes hot rod crank stock stroke. also im gonna get rid of they single carb set up . i have lectrons 38s they would be too big though i think ?? what size carbs would i run for fast trail riding,,were at 1650 ,,also am i pushing it with the 20cc domes on pumpgas. i dragrace and build 4 cyl dragbikes, kinda out ov my comfort zone with the 2 stroker any help will be apreciated.. steve http://tinypic.com/r/erz8fl/5 ALSO I WAS GONNA SET TIMING AT +2 TO 3 DEG IS THAT RIGHT?? Quote
Glenyboy Posted April 13, 2012 Report Posted April 13, 2012 (edited) ALSO I WAS GONNA SET TIMING AT +2 TO 3 DEG IS THAT RIGHT?? You can go +4, that's what most people run Edited April 13, 2012 by Glenyboy Quote
ClayAiken Posted April 13, 2012 Report Posted April 13, 2012 Noss Heads use orings i believe. No you cannot use 38 lectrons on stock motor. Sell them and buy some stockers or 28 pwk's Quote
steve14733 Posted April 13, 2012 Author Report Posted April 13, 2012 Noss Heads use orings i believe. No you cannot use 38 lectrons on stock motor. Sell them and buy some stockers or 28 pwk's Quote
steve14733 Posted April 13, 2012 Author Report Posted April 13, 2012 (edited) i emaild noss. but havent heard back yet., i was thinking it only has a base gasket.jugs then the noss head with only all the o rings, is that the right way to install the head its the r1 2 piece plus the domes..20 cc 6450 bore with stock stroke. stock banshee jugs bored to the 6450 Edited April 13, 2012 by steve14733 Quote
Jereme6655 Posted April 14, 2012 Report Posted April 14, 2012 okay....little more sentence structure would make it easier for s to read your post. But to answer the aftermarket head question......there are no "head" gaskets......only o-rings that go between the top of the jugs and the head. Quote
steve14733 Posted April 14, 2012 Author Report Posted April 14, 2012 okay....little more sentence structure would make it easier for s to read your post. But to answer the aftermarket head question......there are no "head" gaskets......only o-rings that go between the top of the jugs and the head. sorry i need alot ov structure,,thanx for answering that for me. what is the life expectency of them o rings, if it aint over heated, and its torgued right?? Quote
dlnoss Posted April 16, 2012 Report Posted April 16, 2012 use only the orings on the head installation. I answered this before the email, sorry. If you have any questions during the install, call me -David Quote
steve14733 Posted April 16, 2012 Author Report Posted April 16, 2012 use only the orings on the head installation. I answered this before the email, sorry. If you have any questions during the install, call me -David THANK YOU FOR THE REPLY DAVID,,WENT TOGETHER GREAT SHOULD BE TEARING UP THE TRAILS SOON,,,,, STEVE Quote
