hi need help for my choice of cylinder... cub, super cub, cheetah,....421, 465,520...
now I have
35 PWk carb 2x
trinity stage IV head w/19cc dome or 21cc dome
350cc very highly ported with big boost port
I want trie biggest displacement
I want go with +4mm cranck ( wiseco maybe)
I don't want put lot of money...just the best can't do without need work on cranckcase and easy to install
I need suggestion for cylinder/piston/gasket for +4mm cranck and my head and carb
tank you
i want i want i want, but i have no money.
i have an idea, hold your hands out, in one had wish for these things and in the other i will take a shit.
sorry I just want buy cranck +4mm , cylinder and piston
the cranck iit's easy choice with wiseco, so cylinder is very difficult to choice
I don't think have to spend 3000$ on cylinder....
I just want keep my carb 35mm, reed spacer and 35mm carb boots, and my trinity head
If I dont wrote ''I don't want spend lot of money'' I think that read some suggestion of 610cc +10mm and restart to zero point
sorry for misunderstand
What type of riding will this be used for? What are your goals? What is your budget? I can recommend a good setup for you if I know this information. And no, your stock reeds and intake will not work with the Cheetah. The biggest cylinder you'll get to work with stock reeds is the super cub, but that won't work with your trinity head. By reading your first post I would be inclined to recommend the 421 cub or Serval depending on your riding style. Let me know
-Brandon
now the banshee have
trinity stage4 head with 66mm dome 19cc on stock cylinder (ported) with vforce3
the carb is 2x 35pwk without airbox and Prodesing air filter
and ajustable trinity timing plate and dynatek adjustable timing curve with dynateck coil
I only want change cylinder, cranck and dome
what is the bigger cheetah cub kit I can use
with or without machined cranckcase
What type of riding will this be used for? What are your goals? What is your budget? I can recommend a good setup for you if I know this information. And no, your stock reeds and intake will not work with the Cheetah. The biggest cylinder you'll get to work with stock reeds is the super cub, but that won't work with your trinity head. Let me know
-Brandon
ok thanks
I'm now dissapointed for my v-force and my trinity head
So I need to change one of the two.... the better way is to upgrade to cr250 reed and keep my head and go with cheetah?
Have no limit I the budget I just don't want put part in the garbage
I run wood road at fast speed at frequently over 70-80mph and hillclimbing
Without a machined case you can go with a 421 4mm stroker
With a machined case and no epoxy or welding you can go with a 465 10mm stroker
With a machined case and epoxy or welding you can go with a 494 14mm stroker
ok for my dome is 68mm or more? ... 421 and 465 = 68mm bore?
if yes my trinity head have maximun possibility of 68mm or can go larger bore
or if I don't want go over 10mm cranck I need change my head and ... for pass over 500cc
So my best way look for 465 10mm
Edited by 3SGTE
