East Coast ATV will have soon the new 35mm drag axles.. Will be adjustable. Made out of harden Stainless Steel.
Can use all the stock wheel, brake & sprocket hubs on the axle..
If you use billet stock replacements hubs on the 35mm drag axle. It would around 13lbs.
Aluminum 40mm drag axle weighs 10lbs.
Lone Star Racing makes a 35mm Banshee sprocket hub setup for Honda sprockets.
Website: http://www.eastcoastatv.com/
Contact: 610-282-0369
how much is the axle going to cost?? bilet brake and billet wheel hubs and sproket hub are going to cost about the same as a jj+a..
is it stronger than the OEM axle? might be a good option for high HP bikes?
  • 4 weeks later...
Update?
  • 5 years later...
