2006 banshee with pro design cool head with 21" domes. My compression is 120psi isn't that low? Think maybe problem with o-ring cuz im dripping coolant from top right side of radiator(overflow) dripping on top of exhaust. What do you think problem is?
same on both cylinders? take that head off and check it out...
Yes it was the same on both cylinders is that low?
Nah 120's good. I say anything below 100 is rebuild. You might want to find why the coolants dripping though.
Yes I'm thinking of going to modquad single piece cool head and take off the two piece pro design
I would recommend Noss or Chariot. They are both good pieces of work. I have a pro design cool head on mine i dont think mines two peices though. Make sure all the o rings in the head are good then torque down the head correctly then see if it still does it.
