87sheerips Posted March 17, 2012 Report Posted March 17, 2012 Finally got my custom battery box dialed in. Details: precision laser cut/cnc formed/TIG welded from .125" 5052 aluminum powdercoated to your choice sized to fit the battery dimensions you specify (length x width x height) mounts to the air box tabs. allows the use of my coolant relocator bracket so you can keep the coolant res. in the stock position. has a slot in the front so you can hold down the battery with a set screw of your choice. has a hole in the bottom so you can push the battery back out with your finger. has drain holes at the bottom edges. $100 shipped for the box alone (to your specs, your choice of powder color) $120 shipped for the box AND coolant res bracket (again, to your specs and choice of powder color) Paypal: [email protected] Here are some pics of the first box that I did, which fits the battery shown Weight is just under 1 lb Mounted with coolant res bracket. Uses stock bolts on air box tabs. So obviously, this will not work with stock air box. Quote
georgie Posted March 17, 2012 Report Posted March 17, 2012 battery box or an AWESOME tool box. Great job JD. Quote
wacko2000 Posted March 17, 2012 Report Posted March 17, 2012 Wish I still had my air box tabs- would make For a handy tool box Good work as usual Quote
jasons Posted March 18, 2012 Report Posted March 18, 2012 got my order in payment sent. Ready to get my HIDs back running. Quote
87sheerips Posted March 18, 2012 Author Report Posted March 18, 2012 Thanks guys, and yes you could use this as a little tool box! I think I will come up with a top that can easily attach. Quote
iDEAL Posted March 20, 2012 Report Posted March 20, 2012 As good of a guy you will find here!!! I just ordered 5 of them today! Quote
87sheerips Posted March 21, 2012 Author Report Posted March 21, 2012 Box of your choice now available on the website. JDS Battery Box Quote
Snopczynski Posted March 22, 2012 Report Posted March 22, 2012 JD, Does that thing clear the rear shock resevoir when the suspension is full compressed? Quote
87sheerips Posted March 24, 2012 Author Report Posted March 24, 2012 JD, Does that thing clear the rear shock resevoir when the suspension is full compressed? Great question Snop, I have ridden the bike but have not bottomed her out completely. I will do that today and report back! Quote
Snopczynski Posted March 24, 2012 Report Posted March 24, 2012 ok, just wanted to make sure you check. That is the reason the ones I build are angled back. Good looking box. Quote
87sheerips Posted March 24, 2012 Author Report Posted March 24, 2012 Yes, it does work just fine. Since the shock reservoir compresses with the frame, the distance between the box and reservoir stays constant throughout the suspension travel. Quote
So Cal Suspension Posted March 25, 2012 Report Posted March 25, 2012 Yes, it does work just fine. Since the shock reservoir compresses with the frame, the distance between the box and reservoir stays constant throughout the suspension travel. When I saw these boxes, that wasn't even the SLIGHTEST concern of mine, JD. The upper shock mount doesn't move. Great boxes at a great price! If someone buys one of these boxes to do a DC conversion and wants to run some of my LED lights, send me a PM and I'll give you an immediate 10% discount on your LED lights. Quote
87sheerips Posted March 27, 2012 Author Report Posted March 27, 2012 Made some changes to the design, slapped my logo on there and made some changes so the coolant bracket fits like butter. I can make the box fit any battery size. Let me know! Quote
jasons Posted March 28, 2012 Report Posted March 28, 2012 when they shipping out. ready to go ride. Quote
87sheerips Posted March 28, 2012 Author Report Posted March 28, 2012 Three shipped this morning and the remaining two will be leaving Friday morning! -JD Quote
