OK i put a Ricky stator in my bike and now it stops firing on one side right before it hits the power band i gaped both nodes to the same .020 is there something I'm over looking
couple years back I put a 200W ricky stator on my bike and it was a piece of shit out of the box. I thought it was going to be a good upgrade because.........long story. Anyway right out of the box it was shit. Shitty solder jobs, the yellow power wire was not even connected to the fitting inside the water proof connector and the yellow coating wasn't even stripped so that the connection was ever possible. Garbage Garbage Garbage. If you have another option you might wanna try that. JMO, Best of luck cuz I chased my tail forever fixing mine.
could be a stuck rings on the right side i
would do a compression check on it rebuild it if you losts ten psi .and i run rickys crap and love it .
