Guys I am trying to figure this out and want to know if anyone has had similar experience
and make sure I'm headed in the right direction. I just rebuilt top end and this issue I currently have existed prior to
Rebuild...
TORS removed and all plastic connections at harness taped
Parking brake unplugged at harness and also clipped at harness where
it connect to CDI ( bike side)
Primary and secondary coil checked with DMM but boots are shot and not registering at all
Stator and pickup resistance fine
Continuity throughout wire harness
Key switch and kill switch checked and fine
Carbs rebuilt and getting fuel
New carbon fiber reeds
Perfect compression 120 per
Here's the deal... Got the shee to idle well but when I hit the throttle it fell flat.
Not a lack of fuel type of flat on its face but something electric thats holding it back
This is exactly what it did prior to rebuild.....
Now it won't even start and has weak intermittent spark if any which I blame on the coil..
But from what I've read on here it sound like the CDI is bad and keeping it from reving...
Sound right to you guys....it's definitely not a fuel issue as I showed it
To the guy that bored my cylinders and he ageed and mentioned asking you guys
because of your knowledge of banshee's...
