JustA5.0 Posted March 13, 2012 Report Posted March 13, 2012 New to this form. Well im getting bored with the power on my 06 banshee i was wondering what yall would recommend to had more power. I do not wanna bore it or stroke it. I thought about switching to alcohol? whats everybodys recommendations?? MODS so far - Herr jugs dune port, t-5 exhaust, K&N pods, noss head 19 cc domes, ported stock carbs, v-force reeds, wiseco pistons and welded crank. Quote
bigboybanshee Posted March 13, 2012 Report Posted March 13, 2012 Advance the timing, lightened flywheel, dyna ignition, lighten the chassis, all will give you a noticable gain. You won't get anything significant without changing the stroke, but if you just want some more pep, any one of those mods will do that... Quote
dmrhottie Posted March 13, 2012 Report Posted March 13, 2012 Advance the timing, lightened flywheel, dyna ignition, lighten the chassis, all will give you a noticable gain. You won't get anything significant without changing the stroke, but if you just want some more pep, any one of those mods will do that... ....................power upgrade= redline 100hp port job Quote
JustA5.0 Posted March 13, 2012 Author Report Posted March 13, 2012 What about switching to alcohol? Or adding Nos? I wanna make one of the fastest stock bore stock stroke shees. Different ignition is definitely on the list to get. Quote
bigboybanshee Posted March 13, 2012 Report Posted March 13, 2012 What about switching to alcohol? Or adding Nos? I wanna make one of the fastest stock bore stock stroke shees. Different ignition is definitely on the list to get. Are you wanting to dune with this bike or just take it to the strip? Quote
JustA5.0 Posted March 13, 2012 Author Report Posted March 13, 2012 Mostly dune some dirt. No strip. Quote
dirtydownunder Posted March 13, 2012 Report Posted March 13, 2012 it was going so well too, then BAM ! Quote
toytech Posted March 13, 2012 Report Posted March 13, 2012 (edited) Mostly dune some dirt. No strip. what tires you running? do you still have the ellephant ears? put the shee and yourself on a diet. remember rotating weight eats hp. Edited March 13, 2012 by toytech Quote
Larry's Shee Posted March 13, 2012 Report Posted March 13, 2012 http://bansheehq.com/forums/index.php?showtopic=152828 Here ya go. Shut up and show them the money. Quote
06specialedition Posted March 13, 2012 Report Posted March 13, 2012 http://bansheehq.com/forums/index.php?showtopic=152828 Here ya go. Shut up and show them the money. Quote
bigboybanshee Posted March 13, 2012 Report Posted March 13, 2012 If you are duning, then I wouldn't recommend alcohol or nitrous. You'll run out of fuel pretty fast, or will need a 5 gallon tank and extra jug of fuel carried on the back, and with that extra weight, you'd more than likely counter any gains achieved by switching to alcohol. Nitrous is not something you just strap on and hit a button to go fast. It's a lot more complicated than that, and not really ideal for duning to be riding around with a 2.5lb bottle strapped to your bike, for starters. Bottle temp/pressure has to be correct or a lot can go wrong quickly. Your best bet is to finish off the simple stuff by getting an ignition, lightened flywheel, and lighten the chassis...if you don't want to do anything to the bore or stroke. Quote
JustA5.0 Posted March 13, 2012 Author Report Posted March 13, 2012 In the sand I'm running h-haulers 20/10/10 (thank that's the correct size) Thanks everybody for the help. I guess ill just order a different ignition and 4 mil from herrjugs. Quote
WINDYCITYJOHN400 Posted March 14, 2012 Report Posted March 14, 2012 In the sand I'm running h-haulers 20/10/10 (thank that's the correct size) Thanks everybody for the help. I guess ill just order a different ignition and 4 mil from herrjugs. Get some 35PWK's and a set of Shearer small bores while your at it. Quote
dcalsv02 Posted March 14, 2012 Report Posted March 14, 2012 In the sand I'm running h-haulers 20/10/10 (thank that's the correct size) Thanks everybody for the help. I guess ill just order a different ignition and 4 mil from herrjugs. If you go get a 4 mill, you will have to have your jugs ported already for stock stroke. Quote
