im trying to build my banshee my brother blew up on me and i have baught a 4 mill stroker crank with 5 mill long rod i have stalk cylenders and a pro design cool head and was going to get the cylenders ported but was wondering if theres anything special i have to do if i have to run a spacer plate or port it differently or if that setup will work together thank you for your help
Would be best to have the cylinders ported for the stroke, you will need some 795 series pistons I believe, and some stroker domes. I would contact one of the site sponsors for all of those needs. FAST, HJR, and REDLINE are some of my favorites. Good luck.
thank you im new to the building of them so i donkt know 100% what parts i need ile talk to them thank you
if anyone else knows for sure what i would need that would be apreciated , also what would be the the diffrence form the domes i have to race domes just the cc diff or are they diffrent all together
You need to compensate for the +5 mill rod and +4 mil stroke, you do that with the 795 pistons and domes that are recessed 2mm i think. but call one of those guys to know for sure... I just cant remember exactly.
As was already stated, you need the 795 series Wiseco pistons, which have the wrist pin moved 5mm higher. These are used, because of the long rods, but the domes need to be cut, for the added 2mm stroke of the crank. Get your cylinders ported by one of the site sponsors, and tell them to cut you a set of domes for your cool head. The spacer plate is just another place to have an air leak. FAST racing cut my stroker domes.
ok thanks i asume none of the site sponsors are located in canada lol so i gatta pay lots of shiping i guess lol :(
Shipping should not be real bad to Canada. I think Jeff ships worldwide, so he can prob take care of ya. Maybe a few of the Canadians can chime in to shed some light on the subject.
Good information here. Hit up Ride.race.live. He is a Canadian and pretty savy about getting parts from the states.
Another route for the head is to talk to Mull Engineering and have him do his magic on your head. Then you could have a sleeper motor (stock head stock cylinders). This is one of the ideas I have bouncing around in my head. Faster and more power than all the stock motors but looks stock!
Adam
