yagermeister_07 Posted March 8, 2012 Report Share Posted March 8, 2012 Ok. so i got the shee all back together today after adjusting the clutch and changing the exhaust. took it out for a ride up and down the road and noticed that the shifting seems to be sticking . ran it some more and figured out that if im not in the powerband that it shifts fine through all 6 gears. but if i get into the powerband that going from third to fourth is hard to do unless i slow down a little. i have tried adjusting the clutch cable and that didnt work so i thought maybe if i move the shifter lever, nope wrong again . so now im stuck . i dont really have alot of smarts on banshees yet . just got this one arround this time last year, and had to rebuild it. well any info/help would be a big help . thanks for your time and input. Dirk Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 8, 2012 Report Share Posted March 8, 2012 Take a good look at shift shaft. Is claw centered on ecentric screw? Is screw worn? Is the claw loose/wobly on shaft? Look at spring, is it worn where contacts screw? Working on son's shee, discovered worn screw. Looked closer, claw wobbles, spring is worn. Another member posted vid of wobbly claw. Quote Link to comment Share on other sites More sharing options...
yagermeister_07 Posted March 8, 2012 Author Report Share Posted March 8, 2012 i will do that thank you. and do you have a link to that video at all? Quote Link to comment Share on other sites More sharing options...
ticktock Posted March 8, 2012 Report Share Posted March 8, 2012 When you adjust the essentric screw make sure the bike is in gear. First or second it don't matter. Then adjust the claw so that it is even on top and bottom with the shifting pegs on the shift star. Then tighten the lock and the folding washer. Adam Quote Link to comment Share on other sites More sharing options...
yagermeister_07 Posted March 8, 2012 Author Report Share Posted March 8, 2012 Thanks for all the help. I got it figured out. An experienced banshee buddy of mine came over and rode it. I guess I just wasn't getting in it hard enough. Shifts fine now. Thank you again. Quote Link to comment Share on other sites More sharing options...
