what up fellas! I need some help here. My left side pipe is hotter than the right at idle by the way its a new build ... compresion is good stock carbs are synced floats are set ... I'm starting to think my left piston rings arent set causing it to heat up I'm also hearing pinging coming from the hotter pipe but when I hold on to it it stops so I'm thinking its rubbing on something :confused: any suggestions ???
Thanks in advance!
double check everything. swap plug wires, check plugs. if its not getting warm its not fireing... even clean the carb again.
oh yeah I also swaped the plug wires same pipe was still getting hotter, I also cleaned the carbs and shot compressed air through them :angry:
Thanks bro... you guys have any other suggestions ?
both side are firing its just that the left side gets alot hotter quick...
I'll try some new plugs...
if the plugs wet i would say spark issue, and since you already swapped wires im gunna say a new plug should do it. im far from an expert tho so dont rape me if im wrong
No prob brutha! I'm in the same boat.... I just removed the plug wire on the hotter side while in idle and it turned off ...tried the same thing on the colder side while in idle , it shocked me !!! :wacko: and the engine kept running :confused: I'am about to try some new plugs see what it does be back in a few!
just switched the plug on the colder side no difference did the same thing as above I removed the plug wire it shocked me and the engine kept running... I removed the hotter side plug wire and it shut off (no shock) :confused: you think it might be the ignition coil ?
Street is your TORS system completely unplugged? Are the pick-up magnets on the outside of the flywheel clean? Is your pick-up gap set to around .020? Check out the TORS and flywheel pickup. If the flywheel is rusty might want to clean it up and try there.
just tried the ignition coil from my other banshee.... same symptoms :confused::confused::confused:
all junk wires went to the dump with the tors . just checked the pick up gap and its good flywheel is rust free....
Swap out the CDI, leave your coil on, then do the stator with your CDI and try to narrow the problem if you have access to another set of electrical.
Adam
Adam
Adam,
I didnt want to hear that but was one of my next steps in the process of elimination ... I have all the wires soldered to the stator...
any other suggestions before I do that
Thanks!
Edited by streetplatoon
