XXDEF1ANTXX Posted February 21, 2012 Report Posted February 21, 2012 Hey gang, its been a while beacuse I just got another banshee. Anyhoo, my machine has a brand new top end bored .060 over, rad valves, standard carbs with 280 mains, and gnarly pipes. Now I did rebuild the carbs, and got it all together correct and I got her to start up but its revving at like half throttle. I tried to bring the idle down using the air Screw since the idle screws were all the way out. Im thinking maybe the pilot jet or theres an air leak somewhere. Im just hoping to find a suggestion to lead me down the path here, any help would be appreciated. Quote
Surfrjag Posted February 21, 2012 Report Posted February 21, 2012 (edited) check that cable isnt pulling slides open. then check for the air leaks or lean pilots edit: always check for airleaks.... Edited February 21, 2012 by Surfrjag Quote
XXDEF1ANTXX Posted February 21, 2012 Author Report Posted February 21, 2012 How do you adjust the tors to get the same effect as you would by adjust the screw on a normal carb cap? Quote
