njbanshee Posted February 19, 2012 Report Posted February 19, 2012 I'm thinking about parting out a banshee, but i'm not sure the going prices on used parts. Every part is in like new condition and motor is fresh. I'm looking to sell the entire bike FAST. Can you guys give me an idea of what i should ask for each part. I'm going to sell the motor complete and the rest in pieces. 2004 stock banshee frame with title stock plastics with front fenders cut. +6 swingarm with 400ex style carrier/ new bearings, chain, and chain rollers and guides lonestar axle roll design a-arms & tie rods & ends custom axis front& rear shocks valved for + 6 swingarm/ sport riding roll design foot pegs and heel guards roll design shifter aluminum front and rear bumpers renthal bars/ oury grips / cascade extended thumb throttle / billet throttle cover new brake pads/ steel braided lines, block off ips sand stars front tires,and have rear haulers that are optional with sale/ dual petcock from gas tank twin keihin 39mm carbs with oversized aluminum bowls vfroce 3's with stuffers twin k&n cone filters with filter covers shearer small bore inframe pipes and mufflers / cascade exhaust clamps heat guards for muffler piping that goes over the air filters 465cc engine cheetah cub cylinders twister 10 mill crank wiseco 68mm pistons 20cc domes noss cool head cylinders and casing ported by fast cub cylinder was drilled and tapped and plugged for future use of fuel pump duneable overide/ neutral down 1-5 billet cluch basket lock out clutch with fast clutch cover/ new clutch cable. shift star billet impellar/ e/z drain brand new factory stator and flywheel adjustable timing plate billet ignition cover Plus.... all other stock parts. Thanks. Quote
jonvia Posted February 19, 2012 Report Posted February 19, 2012 I'm thinking about parting out a banshee, but i'm not sure the going prices on used parts. Every part is in like new condition and motor is fresh. I'm looking to sell the entire bike FAST. Can you guys give me an idea of what i should ask for each part. I'm going to sell the motor complete and the rest in pieces. 2004 stock banshee frame with title stock plastics with front fenders cut. +6 swingarm with 400ex style carrier/ new bearings, chain, and chain rollers and guides lonestar axle roll design a-arms & tie rods & ends custom axis front& rear shocks valved for + 6 swingarm/ sport riding roll design foot pegs and heel guards roll design shifter aluminum front and rear bumpers renthal bars/ oury grips / cascade extended thumb throttle / billet throttle cover new brake pads/ steel braided lines, block off ips sand stars front tires,and have rear haulers that are optional with sale/ dual petcock from gas tank twin keihin 39mm carbs with oversized aluminum bowls vfroce 3's with stuffers twin k&n cone filters with filter covers shearer small bore inframe pipes and mufflers / cascade exhaust clamps heat guards for muffler piping that goes over the air filters 465cc engine cheetah cub cylinders twister 10 mill crank wiseco 68mm pistons 20cc domes noss cool head cylinders and casing ported by fast cub cylinder was drilled and tapped and plugged for future use of fuel pump duneable overide/ neutral down 1-5 billet cluch basket lock out clutch with fast clutch cover/ new clutch cable. shift star billet impellar/ e/z drain brand new factory stator and flywheel adjustable timing plate billet ignition cover Plus.... all other stock parts. Thanks. how much for roll desgin heel guards and pegs? send pics to [email protected] also looking for some dirt tires 20-11-10 or if you have some already mounted on 9 inch tires thanks Quote
njbanshee Posted February 19, 2012 Author Report Posted February 19, 2012 Nothing is for sale as of right now or it would have been posted in the for sale section. I'm asking for help on pricing. I'm looking for fair prices for both me and the buyers so I could sell it fast. Quote
Surfrjag Posted February 19, 2012 Report Posted February 19, 2012 your going to have to look around to find prices as comparison.. cheaper the better Quote
ticktock Posted February 19, 2012 Report Posted February 19, 2012 2004 stock banshee frame with title $ 275 stock plastics with front fenders cut. $ 225 - 250 lonestar axle $ 175 roll design shifter $ 25 - 45 aluminum front and rear bumpers $ 35 each renthal bars/ oury grips / cascade extended thumb throttle / billet throttle cover new brake pads/ steel braided lines, block off ips sand stars front tires,and have rear haulers that are optional with sale/ dual petcock from gas tank $ 75 twin keihin 39mm carbs with oversized aluminum bowls $ 450 vfroce 3's with stuffers $150 twin k&n cone filters with filter covers $100 shearer small bore inframe pipes and mufflers / cascade exhaust clamps $400 - 450 465cc engine 2500 - 3000 complete cheetah cub cylinders $ 775 twister 10 mill crank $700 - 750 noss cool head 20cc domes 175 duneable overide/ neutral down 1-5 $275 - 300 billet cluch basket $ 125 lock out clutch with fast clutch cover/ new clutch cable. $300 shift star $15 adjustable timing plate $25 billet ignition cover $100 or more depending on type I may be a little off but that is what I would be willing to pay for things Hope this helps, Adam Quote
Bri894 Posted February 19, 2012 Report Posted February 19, 2012 If you part it out I would be interested in the frame. Quote
wacko2000 Posted February 20, 2012 Report Posted February 20, 2012 Bike that this dude is talking about, I bought this morning and took it riding today. So i wouldnt pay to much mind to this post since its in my possession. Joe PS- This is the fastest fucking thing i have ever ridden in my life- Bike is beyond impressive, was built by FAST. Cant say enough about the motor- scary fast to say the least..Infamous and Nasty on here both rode this bike today aswell. 10mil drag ported cub, 39's,shearers on a +4 swinger = :whoa: :whoa: Quote
ticktock Posted February 20, 2012 Report Posted February 20, 2012 Bike that this dude is talking about, I bought this morning and took it riding today. So i wouldnt pay to much mind to this post since its in my possession. Joe Haha, Deletage! Adam Quote
Infamous039 Posted February 20, 2012 Report Posted February 20, 2012 Yup I rode this monster today that Wacko purchased, damn near shit my pants. I could stop shacking after riding it. Now I want a 10mill cub in my garage. Quote
Concrete Posted February 20, 2012 Report Posted February 20, 2012 Are you going to keep the 4 mil or sell it wacko Quote
shakar Posted February 20, 2012 Report Posted February 20, 2012 (edited) Bike that this dude is talking about, I bought this morning and took it riding today. So i wouldnt pay to much mind to this post since its in my possession. Joe PS- This is the fastest fucking thing i have ever ridden in my life- Bike is beyond impressive, was built by FAST. Cant say enough about the motor- scary fast to say the least..Infamous and Nasty on here both rode this bike today aswell. 10mil drag ported cub, 39's,shearers on a +4 swinger = :whoa: :whoa: wheres the pics?? if you dont mind what did you scoop it for?? edit=======scratch that i seen the for sale add. wowie wow very nice that should keep you happy for awhile not too many more goodies to add to that .she's got it all ............. well almost Edited February 20, 2012 by shakar Quote
njbanshee Posted February 21, 2012 Author Report Posted February 21, 2012 Now I know why the dude isn't getting back to me. Glad it found a good home. Quote
