yosteff Posted February 22, 2012 Author Report Posted February 22, 2012 (edited) update: tested today and had same problem as before. Idled well and ran on right cylinder with choke out. Nothing on right without choke, any rpm. Pulled carbs and swapped float needles and floats. set height at 21 mm +-.5mm immediately ran better and idled. could pull 6th gear easily and ran on both cylinders. New problem-leaking out of overflow on that carb. Needle holds when tested for leaks, must be a incorrect height? old float was wayyy higher but didnt leak... May start another post if problem persists Well look like my problem is in the carb then... do you need anyting special to remove the TORS? still have to clean the damn carb... Edited February 22, 2012 by yosteff Quote
VoOK Posted February 22, 2012 Report Posted February 22, 2012 Well look like my problem is in the carb then... do you need anyting special to remove the TORS? still have to clean the damn carb... Its very simple, you dont need anything speacial, just try not to mix up carb parts if you take apart both at the same time. Quote
Larry's Shee Posted February 22, 2012 Report Posted February 22, 2012 http://bansheehq.com/forums/index.php?showtopic=135591 TORS removal Quote
