yosteff
Everything posted by yosteff
  1. Well look like my problem is in the carb then... do you need anyting special to remove the TORS? still have to clean the damn carb...
  2. Cool the carbs are out and about to clean them... I will look at the hose when rebuild it to make sure... Hope that's just that!!
  3. Yes they are still on i try this already and nothing changed!!
  4. I try the bike again after my first post and it was going fine.. so i rev it up and the left side started to cut and backfire.. i let it idle some time and try puting some chock and it was changing a bit but after some more idling the right side stop firering! I remove the carb and reed valve. Is it normal that the metal part of the reedvalve have a greenish coating or it is varnish? . I dinth use it a lost in the last year .. anyway i cleened the reed valve and will do the carb tomorow!
  5. Hi everyone! First post on your great forum. So here is the problem. 2001 banshee start fine and rev good with both cylindre. After a couple of second the right cylindre quit firing??? I clean and retighted the wire leading to the coil (orange and black) . I replaced the right spark plug with a new one and swapped to an other coil and wire and it still doing the same... So it start on the first crank rev good for 2 to 5 seconde Then the right cylindre quitfiring but the bike still running on one cylindre Help me !!!
